What fuel screw setting to use with hypermax turbo?
George_7.3IDI
Fairbanks, AK
I just got finished installing a hypermax pulse turbo setup on my 1992 F350 7.3IDI. At the moment I'm just running the stock fuel screw setting to see if I feel any difference in power before I turn the screw up. I was wondering where I should be setting the fuel screw once I start turning it up or at least what the most common fuel screw setting is that everyone else uses. The chart with the hypermax kit shows horsepower ratings depending on how far you turn the screw from 60 degress up through 240 degrees. On a side note I've got a pyrometer that I will be installing in the manifold as I've got the hole drilled and tapped already for it so that I can keep track of EGT's.
