What do you haul?
Got Smoke?
The Smokey One
Bethpage Tennessee
Well I don't tow a lot of heavy loads, but I'm usually the one who gets the phone call when one of my cousin's toy's needs hauling!:D
Here's his 78-F250 I hauled to our local mud run because this truck has no breaks but run's like a scalded ape!
I also haul my playtoy.
My cousin also has a 92 F-250 Non-Turbo 7.2(I believe :confused:) that I had to haul when the radiator crapped out while I was driving it! :mad: (shoulda got a picture, but he had taken my truck to get work done that I didn't have time to get done) Also I just recently hauled his old Jeep J-10 to get looked at and I have to go get it for him Sunday because its something really bad! I'll make sure and get a pic this time!:D
gwhammy
mo
436b cat backhoe, 4wheel drive, extendahoe. Total gross wt. with me in truck 33,000 lb. Pulls it good,but I don't get in any hurry. Tandem duel 28 ft. trailer with electric over hyd. brakes. Stops fairly decent. Also pull bobcats with all atachments and gross around 23000 lb. on a triple axle 24 ft. trailer.This trailer also has elect. over hyd. brakes with two axles with disk brakes.Brakes are the trick on heavy loads!
BigSix
west central florida
I tow our 10,400 lb 5th wheel. Not quite up to the 13,400 lb tow rating but if it were any heavier I would want a HO Cummins. Does a fine job and maintains 65-70 quite well. Long rolling hills slow us to about 58mph where it holds strongest in O/D. A HO would likely flatten those rolling hills out!
roadranger
Colorado Springs, CO
All we use this truck for IS hauling the toys around with!
10 ft slide in camper, usually towing one of the trailers in sig.
GCWR of 18,500 with the heaviest trailer in tow.
Sixpack
Everett WA
Hi Eric, It's listed @ 27' but it's closer to 29'+. Weighs in @ appx 9000# loaded and ready to roll! :D
Stoked
I don't pull anything but my fat butt around 'cause I don't have to anymore. I sold two single car trailers and bought a 2 car stacker (one on top of the other) that I pull with a FL60. Trailer loaded weighs between 18,000 and 20,000 depending on which cars are in there. Then the trailer is 14' tall and has a nasty aerodynamic load.
Hoss
Arlington Washington
My Trails West 4 horse bumper pull and 8ft Lance camper. A few (5) tons of hay now and then. An occational busted truck and whatever else may come along.
dresslered
Felton, CA
I haul a little 5000-lb. Bigfoot. Looks like I definitely need to work on an avatar! ;)
brb5
