This weekend, I went to go look at a 1994 van w/ a 7.3L IDI. It was for a friend who wanted a cargo van. Any how, we passed up on it since seller wanted $6450 (162K miles)- crazy, KBB says it's only worth $3800 or so. It was extended, XLT, power mirrors, AC.... 3.55 axle ratio (brought the chart to decode), tow hitch, tow mirrors (big old style swing out).
Any how, it started right up after GP-ing. No hesitation in starting (followed the Ford recommend method- 1/2 throttle). But we noticed a slight grayish haze while we looked it over coming out of the pipe. We reved it up and saw some more grayish, but it cleared up after a few seconds. But, when we let it return to idle, just as it settled down to idle, it let out a greyish cloud like someone who was smoking and let a big puff out of their mouth. Then you could just see a slight haze.
I have a 1990 IDI and buddy has a 92 turbo-ed IDI F250. We have never seen either of our diesels smoke grayish. His odo has 141,000 and I'm guessing mine is 155,000 miles.
Inspection under the hood showed that the injectors still had grey paint. Had a valve cover leak and it was odd that the air cleaner housing seemed 'loose'. Saw some oil near the driver side rear, but it prob. was the oil cover leaking on the top side. Build code on the timing gear cover showed it was 93 (in par w/ a 94 model year). Forgot to take off the oil fill to see if there was any blow out of it and how much. (Tranny fluid was nice and red... no smell of being burned).
On the test drive, friend who drove it said it lacked power (but the Car Fax did say the van was a California delivery when new- different HP rating?) Said my 1990 IDI which also has a 3.55 ratio had more power then that van. Plus, the drive wasn't very long... no freeway or anything faster then 40mph. It was ideling about 5 min before it went on the test drive. Saw the haze all the time. My van, you can't see anything when it idles. I forgot to pay attention to it after it came back..... I didn't drive it.
So, were we just spooked at the grayish smoke that we saw? Or was there something there possibly. (The friend we were shopping for plans to use this van for work... and that includes it being loaded w/ about 3000lbs of stuff and going over a mountain pass (small pass), but it has to be reliable....) The lower miles is what attracted me, but seeing the smoke.... I wonder if anything was truly wrong (asside from the price or our sticker shock). I wonder since I saw another truck w/ 220K miles that was for sale at a local dealer at the fuel station today. It sounded worse then the van we looked at and puffed the same haze.....
Comments....
Comments....
