Been seeing the light randomly going to and from work, but checked connections and output... all seems good. Did the 3g conversion last year and all has been fine. So is it something else or?...... Thoughts?
never thought about it, but I have not had an issue after replacing the stock alternator. I did remove/replace the entire regulating harness and used heat-shrink over the one extra wire (green if I remember correctly).
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
