What are the differences between bb and gg injectors?
Full Monte
Campbell, CA
I watched Icanfixall's U-tube side-by-side comparison of bb and gg injectors.
I'm not clear on which type would be used on which application. Does anyone know the answer to this?
hesutton
The Anti-Anderson
Bowling Green, KY
It is my understanding that the G code injectors were changed for better emissions........Not for performance. BB code is all that can be bought new and they are felt to be better for general operation of your IDI.
Heath
That sums it up Monte. For a long time the G codes were felt to be the hot setup because they pop at a higher pressure. Up around 2200 lbs. I talked to Russ in depth about this and he showed me how wrong I was to be running G codes. So I bought a set of Bb from him and wow... What an improvement in mileage and hp. It was like adding two extra cylinders to me engine. I tested the G codes and they were popping open at around 2100 lbs and none were leaking thru or shot. actually they were around 2000 lbs and rather new injectors.
Dieselcrawler
Professional wrench holder
Staff member
Quakertown Pa
go look at the dyno result thread. i posted up a pic of my runs. one with g codes and one with bb codes.
Black dawg
sw mt
I have run both lots of miles, the bb code injectors are better in almost every way, although I lost 2 mpg towing with the bbs compared to the g code. Unloaded mpg is the same to slightly better with the bb code injectors.
I can tell you the springs are differant in the G codes as are the pintels. I'm not able to see into the nozzles but I bet they are differant too. Increaseing the pop pressure in the Bb codes may give us something to talk about here. 1850 is what they are factory set for. Increasing them to 2000 lbs migh give some hp increase. I think this was discussed here with Russ some time back....:dunno
Full Monte
Campbell, CA
I just started another thread asking about the effect of pop pressure on ignition timing. This may be the reason your rig idles so smooth and others don't.
