What am I doing wrong
psy9zach
keego harbor michigan
Got the prob in the hole and this is what I'm getting
Sent from my ASUS_A006 using Tapatalk
Offset is a just a setting, not your actual degree of timing. Iirc, you want 20* of offset with it in the gp hole.
hce
So can i....
Glasgow MT (Official middle of nowhere)
Offset is set correctly
Two to watch for on these timers,
Sand the injection line bare for the piezo clamp and ground.
Pickup basically needs to rub, paper thin clearance.
You aren’t getting a good signal off the crank. It shows the offset if it’s not getting a good crank signal. Been there.
psy9zach
Auto correct on the phone and the fact the words come out faster in my head then my fingers can move is a challenge some times, I had a hard time getting the magnet sensor down in the hole and back out I used a drill bit the same size by hand to clear it out but it didn't go well bc I had to use channel locks just to get it out I was saying in the picture I noticed he didn't have the spring that sits in that grove that I would assume is for holding it still do we have to take it out to get the sensor into the hole like does it make it to wide
Yes I had trouble with mine. I ended up taking the drill to mine. I did also remove the spring clip.
