Yes, the window wipe,s are longer for 80 - 86, then shorter for 87 +
because they chopped off the corner of the Wind Wing. Also moved the verticle post back some.
The door glass is also narrower on 87 +.
This is front doors.
Here is Bronco Grave Yard, they have some for the rear doors.
I bought the Door Seals for the 86, and I could not get the doors to compress the seals.
I was at PNP and pulled a set off a 04 Door and a Half truck. were in ok condition. Washed them up good, found center on them, started at the top of the door opening and worked my way around.
They are longer, over lap them, and cut off the ends.
That part is messed up anyway where people were getting in and out.
For the most part, worked pretty good.
Then I ordered 2 new one`s for a 04, But the newer one`s, instead of the seal being open, they added a center wall to stiffen them up. Now the Pass door stick out some, Drivers door has the old one. and closes ok?
That`s my story, all I know.
