Check the picture below, do you know the thread size of that plug that's in the circle on the picture?
I need to replace the thermostat and while dropping the coolant too i was thinking of installing the coolant filter i've had lying around. My thought was to remove that plug from the water pump and attach a hose to it that goes to coolant filter. But my big question is that, if i take the coolant from that water pump plug, then which hose do i attach the other end of the filter? Do i put a T-coupling to the hose that goes to heater core or to a hose that comes from heater core? I've tried to search is that plug on the water pump meant to be an outlet or inlet, but didn't find any answers. I know the hose next to that plug comes from heater core. I don't want to install the filter inline to the hose to heater core in case filter gets clogged, so i thought this would be the best choice...
Thanks in advance!
Thanks in advance!
