HammerDown
I Fellas, been a while...hope everyone is well.
Water Pump question refresher...on my 1988 7.3 does anyone know where the water pump 'weep-hole' is located?
Looking directly at the engine is it at 12-oclock, 3-6-9? (I'm having a difficult time finding it)
Symptom...
Truck sits dead cold = no leak.
Truck is hot and running = no leak
HOWEVER...turn off hot Engine and pressure builds and coolant is weeping from somewhere???
If I release pressure from radiator cap weep stops.
No coolant in Oil, no Oil in Rad or overflow bottle.
*I don't think it is a bad Water Pump as when they fail they will always drip from the 'weep-hole' while running...correct?
*Possible Water Pump-gasket that is weeping after engine shut off and when engine is hot it's sealing-up?
Difficult to see exactly where Coolant is coming but it appears down behind the Balance...but that could be coming from anywhere above.
Crawling under Truck again to have a look-see.
Thanks for any feedback Ray
Symptom...
