Water in fuel sensor BUSTED!!!
Mr. Fix it
Brighton, MI
Was changing out the fuel filter today on the dodge. The freakin WIF sensor was a little loose, so you guessed it! SNAP!!
Cummins part store is closed today. I have to have the truck for work in the AM.
I found an old radiator petcock (plastic) that threaded in nicely, but it leaks under pressure (when running).
:yell: ANY IDEAS???? Hell, I don't ven know the thread pitch or size. Was thinking maybe a bolt or oil drain plug (correct threads of course), just till I can get the part on my way home from work tommorrow. Thanks, Kevin
Geno
Noble Ok
Wrap the threads real good with teflon tape. Plastic to metal some times dont make a good match
B
Big K
Guest
Take the plastic petcock to the auto parts store, and see if you can get a brass pipe plug in the same thread pitch. Use teflon tape, or, my preference, pipe thread sealant. Be careful not to overtighten.
Mr. Fix it
Brighton, MI
Thanks for the replies. Got it fixed.
I took the housing to the auto parts store and found that a 1/2"x20tpi oil drain plug (and fiber washer) fit perfectly. Cost: $2.50, and I even got the one with the magnet in it. I heard it supposed to make the truck run faster and jump higher or something like that.
Gonna order a new WIF sensor from Genos. When that arrives, I'll make sure that plug stays in the glove box. That way, I'll never need it again. Thanks again, Kevin
