Waste Oil for heating
mankypro
Learning Slowly...
Boulder County, Colorado
I thought I'd post this out of topic subject - I've gotten such good advice from folks here over time I figured you folks would be able to answer.
I have a very old piped galvanized kerosene fired heater in my turn of the century detached garage. It seems to not have been used in 50 years. I'm just wondering how this baby might work with wmo :)
I'll most likely start it up with kero here in a week or two for function testing and then try wmo unless someone warns me off it.
Ironman03R
Risingsun, OH (NW OH)
Ive thought about this also. How does it work? I'm guessing it has a wick that soaks up the K1? I dont see WMO wicking up very well. Also gotta worry about the fumes from it, we use diesel in the salamander sometimes but it takes some tweeking to get it to run smoke free.
mankypro
Learning Slowly...
It has an upside down can with a screw on cap as a reservoir, this has a pressure activated spout which opens when it's put, upside down into it's cradle. The cradle is basically a basin with a wire filter at one end to feed the burder. Flow is controlled by a dial valve. The can mounts directly behind the burner so having the wmo be fluid isn't an issue.
Ironman03R
You could always try cutting it 50/50 and see what happens. I doubt that straight oil will ignite on its own like that, but hey its worth a shot!
