This may or may not be normal IDI behavior, however, I don't usually have a very heavy foot in the morning or whenever the truck is cold, so I've never noticed it before. I was running behind this morning, and after letting the truck "warm up" for about a minute, maybe two, I had to go. I admit, I gave it a lot of go pedal, but that cat just about jumped out of it's skin. It was still on the (warm-up advance?) high idle setting, and seemed like it had a great deal more power than what it has when it's at operating temp, or even after the high idle switches off. Is this a normal IDI behavior, or am I looking at replacing something sooner than I had anticipated? When I say it had more power than usual, I'm not even remotely kidding. I hit 6lbs of boost about 1/2 way through 1st gear with an empty truck, so I grabbed 2nd and eased it out. For comparisons sake, when the truck is "warm" and empty, getting on the go pedal usually builds about 2 to 4 lbs of boost by the top of 1st gear. I was impressed with it's go-power, but it made me nervous enough to post about it. Truck, for what it's worth, has about 330,000 miles now, and an ATS 088, 3" down pipe to 4" out a single stack, T19, and I believe 3.55 gear ratios. So, I guess the question is, am I closing in on an IP replacement faster than I originally thought, or is this normal behavior?
