wap
Max Power
You will have to wait for the dns change to take effect. It could take up to 48 hours but most likely it will only take an hour or two.
Then you can go to http://wap.oilburners.net/
Let me know if there are any bugs although I don't think I know enough about wap to fix them anyways. :(
epin
i'm a cellphone junky. its a terrible addiction to admit to. :(
Max Power
Then dns has reached me here. Let me know if this works. IT uses a redirect so I am not sure if that works with WAP or not.
If the oilburnes.net/wap works so will the the wap.oilburners
Thanks
epin
it works that's the link i just came online with.
epin
just key in wap.oilburners.net now. workin like a charm.
Max Power
Cool! It could take a bit for the DNS to reach everyone but it will work shortly if it doesn't already.
I bet we're the first WAP enabled Diesel site! :D
epin
just testing with the avs on. seems to work fine. takes a little longer to load but could be worth the wait. it really works well.
timntools
Chief Runinscissors
Hendersonville, TN (Nashville)
welp, I got to where it would show my the forums, but it wouldn't show me the threads...I'll keep playing with it, but know I prolly shouldn't, else you'll never get me off here. :sorry:
Max Power
I don't know enough about it to support it. Hopefully Epin has some ideas for you.
timntools
Chief Runinscissors
I'm running Sprintpcs...when I tried, I wasn't able to select a forum, I don't believe. But then again, here at work I don't get the best signal...to many operations going on around me causing interference.
geonc
SPIDER BAIT
NECKVILLE North Carolina
Swany said:
a *** is without papers, derogatory slang for Italians, kinda like daygo
It's :yell: "****" :idiot -cuss if'n you're gonna hurl insults :draw :D LOL
That is why time flies so fast over in Italy..................................
.every time you turn around.....you see a ****... by ;)
