vibration question
C_Luft
Vancouver, WA
I recently swapped engines and went on my first real drive since I've owned her (nearly a year) and I get vibration upon take off, kinda feels like driving on chunky tires for a second and at the same time the transfer case shakes/moves back and forth.
Is this a bad transmission mount or am I just paranoid?
Also my overdrive light doesn't come on but it still works ,
I would like to change the light out or the switch(just in case it blinks) , I have searched the Web and found no real answers.
Do you have the U-joints indexed? The shift switch is available from dealer, the whole shifter is about $57.
laserjock
Almost there...
If you take a drive shaft apart, you are supposed to mark it and put the parts back together in the same orientation or indexed the same. It can cause vibrations if it's not.
Alleycat
