stumpjumper3
I am about at wits end with these flippin vent window. Teardown was easy, until i broke the stud on the frame off. Then the new weatherstripping was less than easy to install. Now that i finally get one together, THE DANG FRAME IS BENT COMPLETELY!!!!! I have a nice huge gap at the rounded corner, thats bigger than when i started! I cannot afford to have the truck down right now and its now looking like a trip to the wrecking yard to try and find a entire assembly that looks like its still sealing to pull and install in mine. UGH! Okay, rant off.
On a positve note, my sound deadening material from eastwood showed up, looks like top notch stuff, and my rear window from LMC. Meaning i can pull the power sliding rear window out and finally have a rear window that doesn't leak.
