blaz4wd
Hello everyone. Hopefully this is a quick painless answer. But I have a '93 extended cab ford f250 non turbo with e40d trans. So question is. is there two vehicle speed sensors? Orilly auto shows two different types one on rear axle and one that connects to the Speedo cable. Is this true? I replaced the one in back on the axle a few years ago but every once in a while I get speedometer needle flutter. It also will effect the cruize control when it does it. I'm wanting to clean the area were the speed sensor goes in and change fluid so I was also going to replace that again with the new wiring harness. Any other ideas on this. Sorry for the long story
