Wouldn't be too worried either way. Too much reseccion (most likely the case) will decrease the effective CR, but probably not enough to make a difference, and even if it does, lower CR is good if you're running a turbo anyway.
Too little could reduce valve/piston clearance, but again I don't think it's so tight where 0.004" over will matter unless you've got a different cam.
