Actually, installing studs requires no torque values at all. All you want to do is thread them in as far as they will go and still be useable. If you are worried about them unscrewing later when trying to remove nuts, just use some red loctite.
If you torque studs into a blind hole, you are forcing threaded material into an unthreaded area at the bottom of the hole. Not good. the result is ruined threads on the stud, and probably ruined threads in the threaded hole if you ever try to remove the stud.
