I wonder what the fill procedure is for that...
Gives new meaning to the term "Check the headlight fluid"
Now it will be "I need to change my vacuum pump oil"
I just remove that bolt, dump out the old, then pour the new oil in until it is level with the hole.
STP is also a good candidate for such applications.
As already mentioned, these pumps care not which direction they rotate; the eccentric on the pulley-shaft works the operating-rod up and down, thus pushing in and out against the diaphragm; the diaphragm cares not which direction the cam is rotating, just that the rod is riding the cam up and down.
A dash-mounted vacuum gauge is simple to install, in-expensive to buy, and an absolute necessity, letting you know the health of the pump and vacuum system.
By using a check-valve in the big line at the pump, a gauge-line TEEed into the hose between the check-valve and pump will show pump vacuum, regardless of any leaks in the system past the check-valve.
Thus, TWO gauges can pretty much trouble-shoot the entire system from one glance at the gauges.
