big van
Nobody Special
My wifes van, 88 E-350 7.3 NA, has an occasional hard brake pedal.
The cruise seems to work ok but sometimes when you push the brake pedal it down shifts to 2nd and the pedal gets hard. Other times the pedal is hard with out it downshifting. I haven't pulled the vac line off the booster to see if it makes a difference or not yet. The pedal is only hard sometimes. Although more often tonight then before.
On the other hand when you push the brake pedal you hear a whooshing air noise. I've heard if the bladder in your booster is bad it will sound like that.
Anyone have an idea? I'd like to have a direction to look before I just start replacing parts.
Thanks, Matt
Thanks, Matt
