gingrass179
hey guys this is going to be a dumb question...
I just started pulling out some serpentine belt stuff that I had laying around and started to install it just to realize I am one pulley short
i am missing either the water pump pulley or the crank pulley they both have the same bolt pattern...
is there a way to tell which pulley I have?
if someone could take a measurement of there crank and water pump pulleys that would help immensely letting me know which one I have and which one I still need...
also I believe this is an internally regulated alternator where as the factory is externally regulated...what wiring is required to make the switch?
last but not least is the high pressure power steering hose the same from an 89 vbelt pump to a 93 serpentine belt pump
thanks guys
thanks guys
