'94IDITurbo7.3
HAMMER DOWN!
Today i replaced the two burned out dash lights that i had. that went good. put everything back together. Go to start the truck up and pull it out of the garage to go to school and the speed is fine at idle but then when i start to move it will peg what ever the max is on these speedos. then when slowing down it will slow down at a normal speed then once the speedo gets to about 10 mph it just drops right to 0mph. by that time the truck is already stopped. all other gauges work just fine. i didn't unplug anything from the back of the cluster other than the light bulbs.
i noticed that my odometer reading now looks like it has some sort of "sploch" in it. kinda like liquid. never had that before today. i have read about not tipping these cluster face down as there is a liquid in them and it will leak out. this cluster never went close to face down today. has worked flawless leading up to now as well.
Does it sound like it is time for a new cluster? that would mean the ODO will be all screwed up as well to right?
Need help fast on this guys!
thanks for any input.
