Cheaper Jeeper
I started replacing the valve stem seals today and ran into something interesting.
The set of seals I got from a local diesel shop had the regular style seals - rubber with the little coiled spring around the top lip to hold them tight against the valve stem - for the intake.
The exhaust seals are completely different though. They are like littl white teflon plastic domes with a hole for the valve stem through the center of the dome.
Well, the surprise came when I started swapping the seals. My engine has the regular style seals on BOTH the intake AND the exhaust valves.
So now I'm wondering if I got the right thing. I'm more than a little hesitant to install these odd looking plastic dome seals for fear that they might actually do a worse job of controlling oil consumption than the ones I'm taking off.
Anybody ever seen/used these white plastic dome-style seals before?
