Update on my new to me 95 ps
fordtuff
arkansas
Well,so far so good. Truck runs well outside of the CPS that every once in a while wants to shut it off coming to or leaving a stop sign or parking spot.
I'm going to have to do a seal job on the front axle and repack the hubs.definatly has to have tie rod ends.
Tightend the two little screws under the dash and adjusted the gear selector and now she's good,tight with no slop. Have to find a headlight knob.. Somebody just HAD to glue it to the shaft so dremmel to the rescue.but have all the dash bezel and trim on good n tight with no squeaks or creeks..
fordtuff
arkansas
Well,100 % sure, no.. But now you mention it, the two times its done it was when I once was leaving a ruff parking lot, I was steering slightly to the right with hardly no pressure on the accelerator, just was about to speed up. The second time was coming into a stop sign with the washboard warning bumps also had a slight right hand steer going on. Humm, both times it immediately fired back up.
thamojster
