wolfman
Just pulled my 4900 lb camper with my 99 f250 SD, 7.3 PSD, 4r100 transmission. Had the transmission locked out of overdrive. About 20 miles into my trip, a sound started coming from the engine compartment that I can only describe as a fan coming on and off constantly. Turning the A/C off would stop it, and going into overdrive would stop it. Even with the A/C left on, it would eventually stop for a while, but would soon return. Towing in SC, so it is pretty flat but mighty hot. Talking to a friend with the same truck with a manual transmission, and he said his did it all the way from SC to Texas and back. Any ideas ? Also, shouldn't this truck be able to pull 4900 lbs in overdrive without trans damage. Thanks.
