Well I cannot speak from experience but I don't see it being a major problem myself...
What issues where you thinking?
Honestly, I can't for the life of me remember who made that plug. The remains are long-gone, unfortunately...made for a good conversation piece before I tossed the remains out When I replaced it, I relocated the plug in the bumper so hopefully it won't be a problem again. I just wish I could find one with a truly waterproof cover.Tim... Is that a leverite plug....
kc0stp, not saying that you're incorrect, but that plug was only submerged for 5 minutes or so...would salt-induced corrosion destroy something like that that quickly?
I see now I didn't have a chance to take the plug apart until the day after it went swimming, and that was when I took those pictures...I had seen the blades the evening the plug went swimming so I knew that it was bad (the blades didn't really deteriorate overnight; don't know about the backside), but even still wasn't expecting it to be that bad I disconnected the wires right after taking that picture just to make sure that nothing would short and make the truck burn down...Tim.... A leverite plug is one that you leverite there where you found er.......
Wow! Still surprising that it could get that bad that quickly... OTOH salt water is some nasty stuff, and live current does make it worse....even still, though...Typically no but it couldve gotten enough water trapped inside (either where the trailer plugs in or where the wires attach) to get a fairly good start before it dried out and unfortunatly once corrosion starts itll feed off itself so untill its all cleaned off will just keep expanding.
