Check valve was covered in crap and stuck, looks like someone used a too long hose piece and it couldnt move at all. So i popped it out and cleaned the ball like new, the port it goes in, and shortened the hose. New IH thermostat, perfectly clean mating surfaces, blew the crap out of the head hole, and installed the high idle sensor thing in the head after snapping an extension (those damn plugs are tough to get out).
Filled the truck up with AF, started it up and the heater core is back to blowing hotter than hell. Looks like that means all the air is bled so I guess I will go on another test drive
took her for a spin, radiator and heater core both got warm this time...
. The picture of hose barb is off the old engine, the uhaul one looked worse
. Don't know where that pic went. I cleaned it up with a metal edge and then wire wheel and the block until both were smooth and clean. And popped out that rubber hose and ball, cleaned the ball and used dremel with plastic wire bit to clean the hole out and then shaved some hose off so it would move freely like it did on the old engine.
