ididieseler
im wondering if i can hook op two oil pressure guages to one sensor, anyone tried it?
im talking about oil pressure guages not water temp, i have an after market temp guage set up already using the overtemp switchidi, there's plenty of port on the heads for sensors. About 4" below the stock temp sensor is the stock overtemp switch that could be removed and the port used, plus there's the same 2 ports on the rear of the passenger head and some others too I think.
w4dsb, I do not recommend that approach as it creates a pocket with no coolant flow so the readings may be inaccurate. You want the sensor to be in the actual coolant flow so it most accurately reads the fluid temp.
There's two ports for oil pressure anyway.
Why even hook up the factory gauge, if you don't like the way it's setup anyways? Jw
Back of the block between the valley lip and the bell housing adapter. Sorta towards the passenger side.where are the two ports for oil pressure?
