Twin I beam help
Fordfan90
Idaho
Hey guys I'm getting ready to lift my truck 4inchs since I can't find a bracket for the one that is broke and bent. I want to replace the bushing for the pivot points what ones do you guys use? I would go to the auto parts stores but are work at are shop has picked up and I'm slammed and everything I keep finding doesn't look like the right ones. Any help would be appreciated.
chillman88
Central NY
Twin I beam as in 2wd or Twin Traction Beam (TTB) as in 4x4?
My TIB 2wd I just ordered the rubber ones from RockAuto, but I want to do Poly bushings soon.
mblaney
Ottawa/Ont/Canada
Go here and enter truck info http://energysuspension.com/parts-search.html
There are other distributors for these so once you have the part number let your fingers do the walk'n
I think if you are lifting 4" you will have to source a new bracket (buy or manufacture) or your camber will be way off. http://pacificfabrication.com/4-suspension-lift-kit-ford-f250-f350-4wd-ttb.html
This is a bit of a cliché but if you are putting that much money and labour into the TTB wouldn't it be better to find a D60? Just so much easier to deal with.
Fordfan90
Idaho
I'm buying the rough country 4inch lift witch comes with the new brackets. I've been looking for a D60 but haven't found any yet in my area.
