Correction: Banks advertised 250/550 flywheel (peak numbers) from the 1st Gen kit. I posted that '87 ad several times here. As with most ads, that is probably a bit optimistic... or optimized... but still a "best possible" number. We've seen some of the member's trucks on the board throw down 210 hp on the dyno (roughly 260-270 hp flywheel) but a low rpm torque number on a chassis dyno is difficult to get (especially on the typical inertia dyno) and interpret. BUT and engine making that much power will likely break the 500 lbs-ft barrier (flywheel) based on what I have seen. IMO, a tight engine/injection pump, with anyones turbo kit (assuming it's not a shade tree hack-job kit) can do 250/500 peak number if the pump is cranked up. That's well within the engine's structural capability and does not impact reliability (much). With the right gear, 300 reliable HP, maybe 550-600 lbs-ft, is possible but that gets to be an expensive build. 400/600+ is pretty much a wet dream for most of us. Doable at large cost and with no reliability left to use your truck as anything but a toy. AN THEN, you will still get waxed by just about everything who just installed a chip to get the same number of level 2. Best to stick with what is achievable within reason and be able to use the truck as a truck. A fresh engine, good turbo kit with an exhaust, head studs, one of Mel's magnificent pumps and a set of injectors...have fun!
