turbo started making excessive whining noise, more like a whooshing noise when under load at operating temperature. Happened after i was giving the truck a good rally down the highway. I thought maybe that the CAC hoses might have shifted under the pressure, so i replaced the hoses with new silicone hoses from diesel power products. Turbo still noisy.
I don't think i damaged the turbo b/c it the truck still drives fine and i haven't noticed any loss in boost pressure. This noise only happens once the motor gets up to 185 degrees, no noise upon startup
does anyone have any suggestions as to what might be causing the turbo to be emitting all the abnormal noise?
05' 5.9l cummins
05' 5.9l cummins
