Thefarmboy21
Ok so I've been working all the bugs out of my 87 that sat for 10 years. So far everything has worked good other than it needs an IP and injectors. Had the injectors tested and 3 are weak, also the truck wont start back after it gets hot. It smokes a bit of grey and white smoke but not using coolant and little oil. Til now I was in ok shape.
NOW I'm dead in the water....or should I say snow! Temps are down to about 20-30 and she hasn't started for 3 days. Cycle the glow plugs, light comes on for a long time, hear some clicking noises, won't start. Try giving it some pedal, won't start. Plug it up all night (dunno if the heater works) wont start. Then out if pure desperation I gave it 3 separate doses of ether and.....won't start?!?!
What's going on? Never known a diesel to not even HIT on ether? Glow plugs were all good a few months ago. Maybe the GP controller??? Idk what to do cause its bad weather and I need my truck! Thanks
