whitehorse
Has anybody used a drain plug kit on there pan? I got one from Napa that uses nylon washers to seal it and was wondering if they leak? I was hoping to install it when I put my shift kit in my C6.
Seems like every kit comes with them nylon washers nowadays, don't like them too much. Go oldschool and buy yourself a variety pack of copper o-rings/washers/gaskets from the Help section of the parts store, costs like $3-$4, it will have the size you need in it. And you only need one copper seal, it goes on the side of the pan that doesn't have the kit's big nut on it - so if the nut goes to the inside of the pan (which is usually where it goes), the seal will go on the outside of the pan. Done a few like that, never an issue.
Try checking ebay for a used pan. I purchased my Mag Hitech E4OD deep sump pan that way. The guy I bought it from even lived here my my town. It gives me an extra 2 gallons of trans fluid and a nice port for the temp sender. The drain plug is sealed by an o ring as is the pan to trans body. Now my biggest fear is how to drain that much fluid without making a mess. And no.. I'm not going to find a field and drain it to the dirt. I will still have to get under the rig in the mess so I need to think this out. A 5 gallon bucket wont fit under there either. Already thought bout that.
something like this would be awesome, kinda pricey, but added fluid is never a bad thing, and it makes fluid changes a snap.
http://www.ebay.com/itm/Transmissio...hash=item1e14ee2e1:g:P4EAAOxyuuJR2LiQ&vxp=mtr
you can buy the 4r100 trans pan.it comes with a drain plug and they run about $40
F81Z7A194BA
tip.
4r100 pans are 4wd depth.always use the 4wd filter when using one.
