i8yr5_0
I have a 3500 dually 2wd. Auto 24 valve. This morning I tried to start it and the key would light everything up but when turned to start it would not turn engine over. After a while of messing with it I put tranny in Neutral and it started right up. Now it will start in park with no problem. However when I drive I'm stuck in first gear. It will not shift no matter if I try it manually or anything I've check fuses, wiring, vacuum lines, only thing I found was that the relay in fuse box under hood for tranny was really hot. Could this be stuck and not allowing it to shift? Any help would be great I'm dead in the water with a trailer and load. Thanks guys.
Rick
Rick
