Trailer brake relay
discbrks
Columbus, GA
I have a trailer brake controller and the harness to plug it in under the dash. Isn't there a relay that I need to install inthe under-hood fuse box to make this work? How can I test the circut to make sure the controller is working properly?
sassyrel
iowa
you have the piece to plug in under the dash--so did my 94--the only problem was that it never had the trailer tow pack--hence no wire to rear of pickup--had to get the right prongs and wire to get it in---this in the block thru the firewall---soooooo the two relays are in a box by themselves--by the fuse box--mine had no trailer charge wire either---cuss
discbrks
Columbus, GA
Hmmmm... well, I thought that if it had the under dash plug then it had the trailer tow package.... maybe not.
EMD_DRIVER
Say what?!?!
Beaufort, SC
Mine has the wires to the rear of the truck, but I have no idea what connector(s) I need to get for them.. Any ideas?
Cv axle
