Traded my IDI for powerstroke
slyhog022056
Grand Prairie, TX
I traded my 91 F350 dually 7.3 IDI for a 97 F250 power stroke 7.3 power stroke. New to turbocharged diesels and would appreciate any input as to pros and cons of this truck. The only questions I have so far is the clutch pedal has to move down 3+ inches before it begins to engage and has to go completely to the floor to keep from engaging the clutch then it only has to come up about an inch to fully engage, normal or am i in for a clutch replacement?? I know for a fact that there is no air in the system because i pulled a vacuum on the system then gravity bled it out after that.
2nd, is 2500 rpm at 70 mph normal for the 5 speed manual?? seems like i need another gear, my IDI (e4OD) locked in high gear only ran 2100 rpm at 70 mph
slyhog022056
Grand Prairie, TX
Already did that, they are new, is that rod adjustable? I crawled underneath and i can easily move the slave cylinder towards the clutch fork about 1/2 inch, wonder if tge arm is bent. When i move the cylinder and let go it returns putting light pressure on tge arm which i know means the throwout bearing rides the pressure pkate all the time. Maybe tgats normal for hydraulic clutchs. I am used to old school linkages.
Randy Bush
Great Falls, Mt
Do you know what gear ratio your rear end is? My 93 dually with 4.10 and ZF5 runs right about there. On the clutch check how much slack your have before the pedal makes contact with cyl and deal with that .
slyhog022056
Grand Prairie, TX
The pedal pad moves down about 1 inche before making contact them another 2 or so before it actually feels like its pushing the fork and pressure plate i think all the slack is on the slave cylinder end i need another person to push the pedal so i watch from underneath.
greenskeeper
PA
remove slave cylinder and measure the distance to the fork. Chances are it's bent if it was never replaced with the updated part.
sounds like you have 4.10 gearing, the axle code of the door jam sticker would confirm.
u2slow
bilge rat
Coastal BC
As already mentioned, sounds like a 4.10 truck. My clutch linkage (95 F350) was so far gone no bushing kit was going to fix it. I replaced the nub with a 1/2" bolt.
My powerstroke experience is why I began cummins therapy. :sly
slyhog022056
Grand Prairie, TX
ok, measure fork end to face of bellhousing, 1.75 inches, removed fork and saw where the fork had been bent by the bulge in the sides of it, bent it back in a press about 1/2 of and inch on the small end and tried it. too much, went back 1/8 inch and that put the fork end about 3/8 of an inch from total collapse of the slave cylinder. that put the pedal total release about 1 inch off of the floorboard. will try that for a while and see how it does. still feels like it is going too far before beginning to release. but at least i don't have to go clear to the floor with it. have to get another cap for the master cylinder and try to vacuum it down again to get rid of all the air in the system.
slyhog022056
Grand Prairie, TX
compressionignitionrules
Bluevale ON
7.3 powerstroke runs best on quality diesel oil and filters and doesn't like dirty stuff. I've done oil changes on high intervals on customers trucks and its like doing a tuneup on a gas engine.
old 7.3 idis will run on any oil product you have handy and will keep goign until they lock up.
you got 4.10s
raydav
Apple Valley, CA
Scan thru here. https://goo.gl/photos/hQSWmXVQ6HsMVWzh6
There are captions.
Seriously consider regulated return fuel supply. It gets rid of the dead head rails. I did the whole thing for less than fifty dollars. And I just replaced the mechanical pressure gauge that came with the regulator with an electronic gauge in the cab; $10. I run at sixty pounds.
And replacing the filter with a frame mounted Racor.
And beware the connectors under the valve covers.
slyhog022056
Grand Prairie, TX
Are the connections going to the injrctors a problem, especially when wet? I need to degrease this motor badly, cant see any actual paint anywhere. Btw, where does the speedo get its signal from. Would love to change rear end ratios but dont want to have to recalibrate speedo. Where can i find a full wiring diagram from? Bought one for a 96 but the colors arent the same, at least not on interior wiring any way. Lots of wires been cut spliced or done awsy with. Even the injection system is cobbled up wires
u2slow
bilge rat
Coastal BC
Did '97 F-series introduce a regulated-return? Electric or mechanical pump? My '97 E-series fuel system was deadhead just like my '95 F350.
Speedo signal is taken from the rear diff sensor.
I debated re-gearing my F350 from 4.10 to 3.54, but I ended up lifting and running 35" tires instead. I never corrected the speedo. It wasn't off far enough to worry about.
EDIT: I used this guide a lot for engine troubleshooting:
http://www.forddoctorsdts.com/fordd...49873DITDirectInjectionTurbochargedDiesel.pdf
