track bar bushings??
troupp
Roaring Branch, pa
Has anyone found track bar bushings for the front of a 4x4 yet, or is this a replace the whole bar kind of thing? Bushings would definitely be cheaper. Thanks
metrojd
Pittsburgh,Pa
Bushings
I got them from the Ford dealer.;Sweet
They werent too bad to replace eather.
I used a socket the size of the bushing and a over sized socket on the other side put it in the vise and pushed the old ones out then pushed the new ones in.:thumbsup:
bryand
Louisiana
check autozone for energy suspension urathane. Ithink I paid around 10 bucks. pretty staight forward to replace.
Double-S-Diesel
parts seller
derry pa
as far as I know fords are the only ones that have the steel on the outside.
other aftermarket ones dont and will not work as well.
Nick
typ4
Newberg,OR
I like my energy suspension urethane bushings, just assemble them with the supplied grease and they will be fine. May not last as long but easy to put in and ford had to special order the factory ones , they said they replace the whole bar in the , and now I know why you guys call it , stealership.
placidoert
