tonkadoctor
Back to working on my own economic stimulus package today.
Decided to tackle the extendable stinger hitch. Had to grind 2' of factory weld seam out of the 4" square receiver tubing.......took 3 hrs with a die grinder taped to a piece of pipe with the handle taped wide open using the air hose to turn it on and off.... (Don't try this at home, I am a proffessional )..... NOTE TO SELF, Remember to order seamless tubing next time DOH!!!
The extendable stinger is needed when I have a trailer or trailers with an actual length of over 28' on the bed. I can load up to 32' of trailer on the bed using my maximum allowed 4' of overhang.
Fit is tight, had to clean up the 3-1/2" tubing of all rust scale and lube it with silicone. Slides free now.
Cut the safety chains to length and installed, Clevis on one end and hook on the other. makes it easy to wrap the chain around the stinger for any length setting I move it out too.
