toe to toe with a cummins!
KyleQ
Minnesota
I get funny looks when I'm flat out banging gears in my diesel. Sounds like a big block until I let it idle - open element air filter FTL.
blown84
Conroe, TX, USA
lol. same here. 3" strait pipe into a 22" long, 4" chrome tip that kicks out in front of the right rear tire. i have no doubt a LOT of people think somethin is wrong with my truck as i come roarin by in cloud of smoke... :slycookoo:rotflmao
MidnightBlade
Shiftin' Smooth
Johnstown, PA
I get alot of people telling me my 460 has a fuel problem and a bad knock at idle (I don't have the Diesel badge on the front)
Or, they tell me my PSD sounds like a gasser :rotflmao:rotflmao
dieselgiant
Dieselgiant
Atmore, AL, USA
Wow, I lost a red light race to 15 passenger van, I did beat a 94 Honda Accord wagon. 115mph is my personal best...downhill of course. One thing I like about our NA diesel's is we will never ever have turbo lag.
blown84
Conroe, TX, USA
:rotflmao i love that. the day after i got my strait pipe put on, a guy at work told me i had a really bad exhaust leak... ;Really
lmao! im not sure if id call beatin a 94 accord a win... ;p
Alex S
Jeoff
New West BC
Having driven a 94 12V cummins with the 5 speed i would say the cummins accelerates the same as my 7.3 5 speed... *off the line* up untill the trurbo spools up but you can feel that they will pull harder giving a load. Having attemped to "race" the cummins and having "raced" my 7.3 the problem is that with the cummins it accels the same as the 7.3 then you get boost for a quick pull for like .5 of a second then you fall flat on your face on the low RPM governor. with the 7.3 you get more RPM to play with
blown84
Conroe, TX, USA
the old 12v cummins were only rated at 175hp, and the 6.9 was 160. with only 15hp difference, weight plays a huge roll.
unfortunately, an 08 has a slightly higher ratin... lol.
Alex S
Jeoff
New West BC
yea no i here ya but i was just making a point that we have the advantage of more RPM to play with. Generally diesels with manual transmissions are kinda useless for racing
pennsylvaniabo
pennsylvania
I outpulled a Cummins coming home from camping yezsterday, he had a smaller camper and wanted to pass me uphill, I was in fourth 2k, 15 lbs, that is my sweet spot all the way to the governor, wife made me slow down. wimmen.:dunno
he had some work done as I could here him behind me, we were both coalin a little:D
But he didnt pass and did give me the thumbs up when we split in town.;Sweet
What is our govenor at? On my '92 the tach turns yellow at 3200 ish.....does it actually have a governor that i can push it too and hold?
FordGuy100
Silverton, OR
Yup, the pump will have a govenor.
If I'm not mistaken, if one of our IP's dont have a govenor spring they run away, correct?
Mine is governed to 3300rpm's under load, and 3500rpms free rev.
pennsylvaniabo
pennsylvania
So how safe is it too push them close to that? I.e i normally dont run it much over 2500
oldblue05
PIN IT TO WIN IT!!!
Caldwell, Tx
Trust me the wait is worth it.:rotflmao:rotflmao:peelout
Thats goin in my sig.:rotflmao:rotflmao;Sweet
Mine stops at 3300... I've gotten there plenty of times in shifting gears, never run the motor over 2500 for extended periods of time. Thats me personally tho...
