timing advance
REBELHIGHBOY
Chester, NH
I have seen this floating around but can't find any information on it what is timing advance controller or thing is?
"Timing advance" is NOT a controller per se. To advance the timing, you rotate the IP (Injector Pump) counterclockwise, this in turn injects the fuel to each cylinder at the correct time. In order to do that, it requires a timing device. Search "timing an IDI.
Matrix37495
The Amish Wolfman
Terre Haute, IN
The timing advance could also mean a small electrical solenoid inside the IP that advances the timing until the engine has warmed up to approx 120°. It is controlled by a temperature sensor that is located to the passenger side of the IP down on the top of the block.
Cv axle
