the worst engineering part of your Ford?
HS108
Diesel Newb
Connecticut
Fords crushed downpipe for the turbo.... Cant believe im on page 2 and haven't seen it yet
Clb
Another old truck
nannyfornia
^^^ cuz they all been chucked in the trash???I'll add...
Vaccume blend doors
Effing dash attatchments
Gauge pannel
The obs pass front seat slider in an extra cab
Fords famous tailgate hardware
Cooling system shortcommings
Lack of a true cold air intake
Paper thin tin on the obs truck
Soso steering collum componnents
Good thing ya did not ask about big bodied chebbies!
FORDF250HDXLT
Maine & Oklahoma
The only actual engineering flaw I'd complain about on my truck is the Dana 50 front end.
Sent from my LG-D850 using Tapatalk
everyone says this.what issues do you actually have with it though? iv never had an issue with mine.
direwulf23
Botkingburg (NCen), AR
You may be right and my criticism may be unfair because the truck is 20 years old. I'm pretty certain it needs considerable rebuilding and the TTB is much more complicated for me to understand than a solid axle and it's not as heavy duty, and expensive to work on.
crash-harris
Breaker! Breaker!
Chillicothe, OH
The alignment on a TTB front axle will change under acceleration/deceleration, under load, road contour, the wind changing directions, a hard fart, etc. However, it does make for a nice ride on a straight/flat stretch LOL
Clb
Another old truck
nannyfornia
Reply to fordf250....
The pivot bushes, the spindles, the diff, the camber change's, tire wear, ease of grenade ability off road.
The simple fact that the sa 44 could have been built to carry the same rating without the weak link center pivot.
But it beats a buggy spring.
crash-harris
Breaker! Breaker!
Chillicothe, OH
Ford did that with 3/4 ton trucks. Solid D44 front, high pinion/reverse cut gears, leaf spring perches, extra ribbing on the cast iron differential case, larger diameter bearings/spindle, larger caliper bracket with dual piston calipers. I converted a '79 solid D44 (cast in wedge year) from 5 lug to 8 lug with HD D44 TTB rotors. Spindles where the same diameter, just different flange/bolt pattern.
FORDF250HDXLT
Maine & Oklahoma
22 years old and so far so good.i replaced the ball joints and tie rods but as to be expected i suppose.i have her lined up every year at the beginning of the season.i always have even tire ware.my off road is just grass though i'll admit.;)
MTKirk
Billings, MT
I put airbags on my D-50 so it could handle the weight of my plow. A side benefit is that now I can dial in the camber year round (carry a bicycle pump in the cab for fine tuning), tires have been wearing nice & even. Still; the design of the thing (D-50) makes my head hurt.
Clb
Another old truck
nannyfornia
The ttb in the 93 does ride better than my 88 did,I forgot to add the sucky turning radius!
I miss that the most.
