EvergreenRanch
In Transition
Starting with the bad :
the rivets and bolts on almost all of my structural crossmembers (the fronts went first, but the additional frame movement wrecked havic on the rest) have loosened, elongated the holes, and were causing my frame to move around everywhere, causing all sorts of issues with alignment, tire wear, handling, articulation, doors fitting incorrectly in cab frame, bed of truck displacing to the side of the vehicle almost 2 inches on a tight turn, and the REALLY bad, a 3 inch hairline crack in the drivers side frame behind where the steering box mounts on the other side and extending in behind my shock's upper mount .....it was literally getting scary to drive after about 2 weeks of steady decline in quality of driveability.
ok, the good:
is that i figured this out before i had a catastrophic failure on the road. also good, is that im getting a new set of polished aluminum wheels out of the deal for next to nothing. highly polished mag aluminum wheels, polished center caps, polished lug nuts, wearing new 33" agressive all-terrains, $600 mounted, balanced, and on the truck....and the best part....almost 20 lbs reduction in rolling weight. i almost didnt believe him when he told me that the 2 inch wider wheels mounted with bigger and wider tires than i had before weighed 4.8 pounds less a piece than my steel rims and smaller tires. customer had ordered the wheels, had them highly polished, the tires mounted, paid for the tires only, then never picked them up and they had been collecting dust in the shop for a couple years. i verified the bolt pattern and told him to put them on.
the ugly:
im good with a welder, im pretty good at vehicles in general, but when it comes to something as important as the frames structural integrity and alignment being permanently if i screwed up.... im having the shop align the trucks frame, weld the living hell out of everything they deem necessary, then re-enforce were they feel necessary with more welding, and then do the regular wheel and suspension alignment. god im glad i just made my next payscale, cuz its gonna be out the door with the wheels and everything about $1,100
im going to post pics of the welding, wheels, everything after i get the truck back on monday.
and finally, has this ever happened to anyone else? the rivets loosening and working the holes to this point? im assuming this has been going on a long time and has just now gotten exponentially worse?
more to come...........
ok, the good:
the ugly:
