Test port location on VP44?
dank1945
Hippo Hands man
St. Catharines/ON
Could someone chime in with the exact location of the test port on the VP44, please?
I would like to connect my fuel pressure gauge into it.
Thanks
Pele
Virginia
There isn't a test port on it. You have a couple options for fuel pressure readings:
There's a Schrader valve on the fuel filter housing that you can use.
There are replacement fuel filter housing lids that have a 1/8th NPT tapped fitting for fuel pressure reading.
You can get a Tapped Banjo Bolt to install in your VP44.
Pele
Virginia
placidoert
