Taps
PowerStroker444
Burnin' Oil
Reno,Nv.
Ok, gauges ordered. Coming from a Ford I need to know where everyone is tapping for boost, pyro thermocouple and trans temp thermocouple. Pics would be helpful.
Thanks!
Dieselmaster
Diesel addict
Lake Havasu - Arizona
Thanks!
I don't have pics.... go to http://www.dieselpage.com/gimain.htm they have full install instructions...
I used their instructions... Boost, I tied into the MAP sensor line by the oil fill tube...
Trans... on the drivers side of the tranny towards the front is an inspection port that you can pull the plug out and place the probe in...
Pyro.... pre turbo ... I used the clamp on... drilled a hole about 1" on the side of where the exhaust manifold & pipe meet up ... Hardest part of the whole job was convincing myself to drill a hole in the exhaust pipe...
Good luck and have fun...
