Tank Pulling A Vacuum/Pressurizing ?
Worstenemy453
King George, Va
When i run on my rear tank for a little bit and then go to fill it up it will either release or suck in air as soon as i open the gas cap. Kinda like when you open a tennis ball can. I haven't figured out if its sucking air in real quick or pushing it out real quick but my front tank doesnt do it. Is this an issue ?
Dsl_Dog_Treat
Decatur,MI
The rollover valve has a 1/4 line to it that does allow the tank too vent so it doesn't draw a vaccum.
What happens 99.9% of the time is them dang pesky mud dauber wasps lay their egg in the end of the vent tube and mud it shut thus plugging the tanks only means to vent.
The vent tube if unmolested will come off the top of the tank and terminate up to the frame rail drivers side.
Worstenemy453
King George, Va
Could that effect the way it runs on that tank and can i access that vent without dropping the tank.
LCAM-01XA
my very own hell
Yeah you can access the vent, Ron ain't talking about the rollover valve itself, just the end of the rubber line attached to it - that's on the inside of the drive-ride frame rail IIRC, before the crossmember the tank straps attach to, pretty much right above the axle.
Alse, on your other question, yes sometimes this can affect the way the truck runs - mine don't, several others reported issues in a thread from a month or so ago. I actually pulled my o-rings on the caps and that solved my venting issue, in your case tho just check the rollover valve vent tube like Ron suggested.
Worstenemy453
King George, Va
I will look for it when i stops raining. I usually only use my rear tank once a week or so and keep it filled for when my front tank gets close to empty. Neither one of my gauges work right.
I concur with what Ron has posted. Time to get wet and find out whats plugging up the vent time.
Worstenemy453
King George, Va
If i fill my rear tank completely to the top and then not use it. When i go to fill up, the rear tank will still want 2 or 3 gallons to get back to where i filled it. Is this normal too ?
Dsl_Dog_Treat
Decatur,MI
Well if the tank isn't leaking then thefirst thing that comes to mind to cause that could be that the foam from the prior fueling has settled allowing more to be added.
Unless the FSV isn't completely switching over allowing a partial draw from that tank.:dunno
