Here's a couple from the Mobil site. All the major brands have a fact and fiction answer guide like this.
Myth: You should break in your engine with conventional oil, then switch to a synthetic oil like Mobil 1.
Reality:
You can start using Mobil 1 in new vehicles at any time, even in brand new vehicles. In fact, Mobil 1 is original equipment (it is installed at the factory) in:
Acura RDX
Aston Martin
All Bentley Vehicles
All Cadillac Vehicles
Chevrolet Corvette C6 and Z06
Chevrolet TrailBlazer SS
Chrysler 300C SRT-8
Cobalt SS S/C Coupe
Dodge Caliber SRT-4, Charger SRT-8, and Magnum SRT-8
Jeep Cherokee SRT-8
Mercedes-Benz AMG Vehicles
Mercedes SLR
Mitsubishi Evolution
Pontiac Solstice GXP
All Porsche Vehicles
Saturn Ion Red Line and Saturn Sky Red Line
Viper SRT-10
One of the myths surrounding synthetic oils is that new engines require a break-in period with conventional oil. The fact is, current engine manufacturing technology does not require this break-in period. As indicated by the decisions of the engineers who design the high-performance cars listed above, Mobil 1 can be used starting the day you drive the car off the showroom floor. Watch our answer to this myth.
Myth:
Mobil 1 can't be used in diesel engines.
Reality:
Yes it can.
For heavy duty truck engines that require API CJ-4, CI-4 Plus, CI-4, CH-4 or CG-4, there's Mobil 1Turbo Diesel Truck 5W-40*.
Be sure to check your owner's manual for the oil quality recommended for your diesel engine.
Heavy duty trucks requiring a viscosity other than 5W-40 should consider one of the Mobil Delvac 1300 Super products. Mobil Delvac products can be purchased at a large number of truck stops across America, and select retail and auto parts stores, as well as from ExxonMobil Distributors.
*When buying Mobil 1 Turbo Diesel Truck 5W-40, please check your bottle labels while inventory transitions to the new CJ-4 formulation.
Updated May 2009
Myth:
Mobil 1 will leak out of the seals of older cars.
Reality:
Mobil 1 does not cause leaks. In fact, new Mobil 1 was tested in dozens of industry standard and original equipment manufacturers (OEMs) tests to prove its seal performance. It is fully compatible with the elastomeric materials from which all automotive seals and gaskets are made. If an older engine is in good condition and does not have oil leaks, Mobil 1 provides the same advantages as when used in a new engine. ExxonMobil recommends taking measures to repair the leaks, then using Mobil 1. ExxonMobil also recommends following the automobile manufacturer's manual for the proper oil to use. Also watch our answer; it's myth four of five in our online video.
http://www.mobiloil.com/USA-English/MotorOil/Synthetics/Myths.aspx
