Synthetic Mercon
bird hunter
Maine
Does anyone know where you can find synthetic Mercon ATF for the ZF? I understand the best ATF for these is synthetic Mercon, but NOT Mercon V. I just can't find any - I can only find the dino Mercon or the synthetic Mercon V. Anybody know who makes it and where you can get it?? :dunno
Thanks in advance.
idiabuse
Princeton Fl
Manual Transmission,S5-42......MA
Synthetic Multi-Vehicle Automatic Transmission Fluid (ATFQT)
Torque-Drive Synthetic Transmission Fluid (ATD1G)
APPLICATIONS
AMSOIL Synthetic Multi-Vehicle ATF is recommended for transmissions, hydraulics, power steering and other applications requiring any of the following specifications:
• GM DEXRON® III-H
• Ford MERCON® & MERCON V
• ZF TE-ML 03D, 04D, 09, 14A, 14B, 14C, 16L, 17C
SERVICE LIFE
Recommended for 50,000 miles in severe service* and 100,000 miles in normal service;* or per vehicle manufacturer-recommended intervals, whichever is longer.
Product Applications
AMSOIL Torque-Drive is recommended as a direct replacement for TranSynd Synthetic ATF in heavy duty, on- and off-highway automatic transmissions manufactured by Allison,® General Motors,® Ford,® Voith® and ZF® or wherever the standards TES-295, TES-389, C-4, Dexron® III, Mercon,® Voith 55.6335.XX (G-1363) or ZF® TE-ML 14C are specified. Examples of operations that benefit from using AMSOIL Torque-Drive include municipal or transit buses, motor coaches, garbage haulers, motor homes, delivery vans, emergency vehicles, school buses, dump trucks,
utility vehicles, cement trucks, line haul trucks and tow trucks.
u2slow
bilge rat
Coastal BC
Mercon V now supercedes original Mercon.
I know it didn't use to be that way, but Ford has amalgamated their requirement.
I don't recall if it was on here, or another forum I frequent, but somebody recommended a 50w synth ATF from medium/heavy truck applications. I'll be checking into that for the next trans oil change.
