Switching tanks
kbenz
kannapolis, NC
About how long does it take after switching tanks to get new fuel through the system? 7.3 non turbo
Kizer
Denton, Texas
Not long, if you’re running down the road, and you accidentally drain a tank, you have time to switch tanks before you stall the truck.
Cubey
Van dweller
USA
I switch tanks when driving and the engine doesn't notice. The injection pump has some suction of it's own, so it can borrow from the fuel filter if it needs to while the tanks switch in the second or so it takes.
The few times I've accidentally ran a tank dry enough to stall, I usually dow shift one gear and press the accelerator to max, usually the engine restarts itself. Also, not a good thing to do, to run it dry, it's bad for the pump.
Kizer
Denton, Texas
Yep, that will sure “do the trick”.
I guess that I’ve learned: If I “suddenly” experience air intrusion symptoms, flip the switch!
Clb
Another old truck
nannyfornia
I'm always headed uphill pulling the dang 5er in the 93 now empty and flat it will just catch about the time panic sets in using Nero's method.
Op it's a crapshoot.
Even with the Holley red I aint warm and fuzzy when this happens.
My 88 would switch on the fly easily, but drain it, not so well.
When I'm cruzing along and I detect WMO problems (fuel filter clogging) I switch to my diesel tank and within a mile, like before half a mile, I'll start gaining momentum again. So, baced on that, if you figure it takes a moment for the diesel to kinda "scrub my filter", to switch must be pretty quick. Maybe look at the GPH rate and guesstimate.
Clb
Another old truck
nannyfornia
fwiw
crawl under the fsv have someone hit the dash switch with power ON and listen to how fast the solenoid moves the valve....
It should ppopp like half a second or less.
if it lags and or does not make a noise it may be stuck {lookup old bulls fsv 101 in tech} showerheads are notorious for this
I've seen it work and I've seen it not work. There's a lot of different factors that determine whether or not it works.
In my case I was on the freeway doing 60, by the time it restarted I was down to about 45ish. Only ever done it twice. I try not to do it.
12pilgrim
Nashville
'86 6.9. I replaced both sending units and the fuel tank selector valve and it switches beautifully, no issues so far at all. I can look up the part numbers that I used if you're thinking of replacing anything
kbenz
kannapolis, NC
I have an almost new oem one on the shelf I took off when I put the wheel lift under it.
I’m running wmo. I was just wondering if I forgot to switch tanks how long would it take to clear the oil at an idle
Alleycat
