If your not extending your drain intervals and don't care about the added protection of Synthics than there is not a problem. Make sure your changing the oil in the high pressure oil resevoir. There is 3 quarts in there that don't cycle very well and you won't see anything in the Ford Manual on how to change it. It lubes the injectors.
If it is Syn i'd at least go 10k I get 6 to 8 on dino, I'm going to 8 on syn in my gasserthanks guys. when i bought it, it showed that rotella t6 5w40 full synthetic had been run. i ran 15w40 scheafer full synthetic in it this time. it cost me $114 with my discount for oil and filter. was planning on going 5k miles on this change but the 3k mark is about here and i wanna go on and change it. was planning on running delo 15w40, but ive been reading about this rotella heavy duty 10w30 synthetic blend. it seems like the way to go and only $16 per gallon vs $25 per gallon that the scheafer cost.
