Stuck Glow Plug - Success
PossumTruck
Michigan
Well, here is another stuck glow plug post. I finally got it out after owning the truck for 4-ish years. When I bought the beast, 3 of 8 GPs were stuck. 2 came out with the visegrip/wire/hammer method, but the rear on the driver's side was a ****** and there just wasn't room to get a good swing with a hammer back there. So I threaded it back in and for 3 years drove regularly with 7 GPs doing the work of 8.
Well, I switched over to black diesel this year and, as it gets colder, good glow plugs are clearly a must. I've had a manual button for some time (and now have a 2-tank system so I start/stop on 1202), but I could tell that I need everything I can get to get this pig going in the mornings under 40*F, if oil is in the mix (block heater fixes all, of course).
So I looked into, and purchased, a leroy diesel GP extractor. I don't like spending that much on a single-function tool, but it seemed my best option. So I went in an did it. And it worked. Found a delphi GP-8 with a super swollen tip and also a bit bent (probably bent from my original extraction attempt). It came out, but I was worried at points given the force on the ratchet felt a bit like I was about to break off a spark plug in a head.
I can also say that Im glad to have pre-purchased a gross of 111 viton orings. I had to move the return lines to get at that rear GP, and it leaked diesel as soon as I moved it a froghair. new orings and no issue.
The truck fired up very well after I buttoned it all back up. I had an extra glow plug in my cabinet, of course, since I could only replace 7 the first time.
Well, I switched over to black diesel this year and, as it gets colder, good glow plugs are clearly a must. I've hade a manual button for some time (and now have a 2-tank system so I start/stop on 1202), but I could tell that I need everything I can get to get this pig going in the mornings under 40*F, if oil is in the mix (block heater fixes all, of course).
You can rent out your GP puller to the rest of us.
PossumTruck
Michigan
Its free to use with your visit. I also have one of those NOS government timing-devices that I continue to put off using - best ~$200 I ever spent... I ran into one road block (opening up the hole to accept the balancer probe) and consequentially found a bunch of other projects that seemed more valuable, but really aren't, lol.
Michigan just isn't in my future.
Can you set timing with just that? My kit definitely has the #1 connector - I just thought you needed both?
Totally off topic, but I take advice where I can get it.
You also need a timing light. This method may cost more, but fewer people seem to have problems with the timing light set up compared to the mag probe.
Brian VT
Maine, USA
I didn't want to spend the $ for the light.
But I didn't have much luck opening up the hole for the probe. Maybe my drill bit was a bit under-sized?
I ended up sanding down the probe a bit. But it works fine for me now.
